Help cant get out of park.
Old Jun 3, 2013 | 10:02 PM
Rgscott67's Avatar
Just put on rims that i picked up off the forum. When i got finished and tried to go for a drive the slip light was on and the car wouldnt shift out of park. Put old wheels back on and same thing, wont shift out of park. Car was perfect beforei changed the wheels. Any help is appreciated.
Old Jun 3, 2013 | 10:39 PM
KrazySouthG35's Avatar
Try unhooking the battery for about 15 mins and hooking it back up maybe?
Old Jun 3, 2013 | 10:41 PM
Rgscott67's Avatar
What will that do? Sorry i know little about cars. From reading it seems it might be the brake/stop switch.
Old Jun 3, 2013 | 10:54 PM
Probably nothing but It couldn't hurt. I've never heard of anything like that happening
Old Jun 4, 2013 | 01:23 AM
petro2342's Avatar
Does your gauge cluster show what gear you're in? If not, then your fuse is blown which is located under the car near the transmission.
Old Jun 4, 2013 | 01:39 AM
dukehotty's Avatar
In for remedy.
Old Jun 4, 2013 | 06:17 AM
Blue Dream's Avatar
I drove ttrank's car solo
You should be able to push the Shift Lock button to get the transmission to shift out of park, but not sure that would help anything.
Old Jun 4, 2013 | 09:03 AM
Mustang5L5's Avatar
When you step on the brake, do you hear a click in the shifter area?
Are the wheels the same diameter? Is the tire size the same? Is your car AWD or RWD?
Old Jun 4, 2013 | 11:32 AM
KingoftheRoad1's Avatar
Let's not get too complicated here. This is the method I would try first. Make sure the engine is OFF, use a small screw drive to move the Lock button, shift the transmission. Try this method first.
Old Jun 4, 2013 | 11:35 AM
drkay's Avatar
^+1 i had a similar issue when i was wiring my 3rd brake light and i blew a fuse. when you step on the brake does the rear brake lights come on?
the culprit fuse was located in the driver side kick panel
b2autodesigns
Accessories-Vendor
84
Jun 20, 2017 04:38 AM
Mick_L
Aug 25, 2015 04:27 PM
franniestopdat
South
Jul 18, 2005 12:41 AM
