Need help with remote
Old Jun 6, 2013 | 11:36 AM
damman98's Avatar
Recently purchased 2003 G35 sedan. It came with 1 key, and found the fob in the glove box. I put in a new battery and it does nothing. I see you can purchase the fob on Ebay, 2 for $15.00 and they state you can program it yourself.
After searching through some threads on here, I can't find a clear explanation. I would love to get this fixed as my daughter is using the car in Boston and i consider it a safety issue more than convenience.
Thanks in advance.
Old Jun 6, 2013 | 01:27 PM
damman98's Avatar
Ok, let's try this. Anyone bought this and did it work for you?
http://www.ebay.com/itm/2-NEW-4-BUTT...94ab1b&vxp=mtr
Old Jun 6, 2013 | 02:32 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Try this
1. Close and lock all doors with the driver’s side power lock/unlock switch.
2. Insert key into ignition and remove it from the ignition key cylinder at least six times within 10 seconds. Your Hazard
Lamps will flash if you have performed this step successfully. NOTE: Withdraw key completely from ignition cylinder
each time. If this procedure is performed too fast, system will not enter programming mode.
3. Insert key into the ignition cylinder and turn to the ACC position.
4. Within 5 seconds, push ANY button on the remote transmitter. Your Hazard Lamps should flash. NOTE: Do not press
the button more than one time in the above step. If the button is pressed more than one time, the programming
procedure will not be successful.
5. If there are any remaining transmitters (including the old ones), unlock then lock all doors using the driver’s side
power lock/unlock switch and within 5 seconds, push ANY button on the next remote. Your Hazard Lamps should
flash. Repeat this step for each transmitter (including any existing transmitters).
6. Turn the key to the OFF position, remove keys from the ignition, unlock doors using the driver’s side power lock/unlock switch and open the driver side door
Old Jun 6, 2013 | 02:39 PM
damman98's Avatar
Thanks, I'll try it.
Old Jun 13, 2013 | 10:42 AM
spaceghost1975's Avatar
Just curious, did it work?
~phil~
Old Jun 13, 2013 | 12:04 PM
KrazySouthG35's Avatar
Yes it works that's how you program them
Old Jun 13, 2013 | 04:23 PM
well I know that's how you program them, but I was more curious if it worked for him since he did find the FOB in the glove box....
~Phil~
Old Jun 14, 2013 | 08:34 AM
damman98's Avatar
~Phil~
Phil, I tried the one from the glove box and i couldn't get that one to work but once I got the new one from Ebay, I did get it to work after a couple of tries. Daughter is thrilled.
Thanks
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
NailBomb
Oct 28, 2015 07:53 AM
JustinMKN1
Sep 18, 2015 03:40 PM
