2005 Infiniti G35X front end vibration.
Old Aug 2, 2013 | 05:37 PM
TSalzNC's Avatar
I have a 2005 Infiniti G35X with a vibration in the passenger side front end. It is most noticeable from about 45-65mph. The vibration doesn't change between braking and just driving. I have checked tire balance and rotors and found no problems. I have also checked the tires for play to see if it's my bearings. I have read other post were people didn't have play in the tires but still had bad bearings. The car has about 90,000 miles on it and riding on a set of Nexen tires. I need some help figuring this out without having to pay a machanic to look at it.
Old Aug 2, 2013 | 06:05 PM
jookyshank's Avatar
I haz hugz to givez
I'm spoiled that I have a mechanic in our car club but one thing you may want to check is your front drive shaft. We found a good amount of play in mine and upon removal it was nearly seized on the diff side and a good 1/8" too much play on the leading joint. We replaced it (EXPENSIVE) the issue with my X subsided. worth a look if you've trouble shot the "easy" ones (hubs, tire balance, etc)
hope this ISN'T the issue with your G, but it sure was on mine
Old Aug 2, 2013 | 09:26 PM
TSalzNC's Avatar
Is there any way you could take the front drive shaft out and make the car RWD?
Old Aug 2, 2013 | 10:35 PM
The_Silencer's Avatar
You can remove a fuse by the driver's left foot and it'll deactivate AWD.
Old Aug 3, 2013 | 09:39 PM
Mustang5L5's Avatar
Sell your car and buy an RWD car.
rezendvous420
May 31, 2020 01:26 PM
newg37
Jul 26, 2015 09:32 AM
Blakelyg35
Jul 22, 2015 12:08 PM
Blakelyg35
Jul 21, 2015 12:49 PM
