Anyone know what this Hose is Called?
Old Sep 16, 2013 | 02:46 PM
pjgangsta's Avatar
G35X Revup
I was removing some heatshield underneath my car because it was rattling, and came across this hose that was covered in grease and oil. It probably needs replacing. Is this the lower radiator hose?
Sorry about the pictures I was under the car and my phone apparently
doesn't focus well.
It looks as if the hose is thin and around 4-5 inches long and connects to the bottom of the radiator.
Attached Thumbnails Anyone know what this Hose is Called?-20130916_130528.jpg   Anyone know what this Hose is Called?-20130916_130538.jpg
Old Sep 16, 2013 | 05:10 PM
SxExCx's Avatar
looks like the hose to the transmission cooler...yes...definitely is.
Old Sep 17, 2013 | 06:03 AM
Blue Dream's Avatar
I drove ttrank's car solo
I wouldn't worry so much about replacing the hose as I would trying to figure out what's leaking on it. That doesn't look good........ My car has 120K and I've never had anything like that in that area, you might have a radiator leak somewhere.
Old Sep 17, 2013 | 09:31 AM
Mustang5L5's Avatar
I agree.
IS that coolant, or Trans FLuid?
Old Sep 17, 2013 | 10:56 AM
pjgangsta's Avatar
G35X Revup
So a Transmission Cooler Hose?
It seems like is Black Oil on it. I think Im leaking Oil.... But I don't notice any oil leaks on my driveway....
I remember replacing the O ring gasket 2 years ago. Can't trust Jiffy Lube these days...
Old Sep 17, 2013 | 01:27 PM
Mustang5L5's Avatar
It looks reddish now that I look closely at it. I can't tell where the leak is, but it might be as simple as moving and retightening the hose clamp.
Grab some gunk engine degreaser and clean the spot. Drive it for a day and then recheck to confirm where the leak is coming from and then repair it. Degrease it again, drive for a day or two and make sure it's leak free.
Old Sep 17, 2013 | 01:35 PM
SxExCx's Avatar
If it is reddish...it is tranny fluid
Old Sep 17, 2013 | 03:10 PM
Blue Dream's Avatar
I hate it when my tranny leaks fluids, gotta get him to clean up before he leaves......
Old Sep 17, 2013 | 08:09 PM
thewinnipegjets's Avatar
Hey oh!
Old Sep 17, 2013 | 09:01 PM
markc's Avatar
Somebody has been in there b4, 'cause those aren't o.e.m clamps on the hose(s). The fittings that go into the rad look pretty rough too. If you're lucky, just a hose and a clamp. If you're not, could be replace the fittings or even rad and clamps and hoses. Clean the area and check it out.
Old Sep 19, 2013 | 02:48 PM
pjgangsta's Avatar
G35X Revup
I'm confused is it an engine oil cooler hose #5 with #6 clamp.
Or the cooler hose #20 but no clamp there....
I ain't lazy just trying to get some advice from you experts.
Attached Thumbnails Anyone know what this Hose is Called?-3840030.gif   Anyone know what this Hose is Called?-3840047-1-.gif
Old Sep 19, 2013 | 03:03 PM
HotRodG35's Avatar
Its none of the hoses you have pictured. Its for the transmission cooler not engine coolant.
Just need to purchase standard transmission or fuel line from auto parts store and cut to length.
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
