Heat not working tried searching
Old Oct 8, 2013 | 06:46 PM
Mustang5L5's Avatar
Yup.
Old Oct 8, 2013 | 08:42 PM
AARONHL's Avatar
Originally Posted by OnlyGoWOT
Wouldn't there be more serious symptoms if there was a coolant leak other than just the ones i mentioned. It will blow heat at 76 degrees and up from idle or cruising just I would think it should blow lower too.
What I am getting at is that you probably don't have a serious coolant leak. You most likely have to bleed the coolant system because air got into it causing the messed up heating symptoms. It is very easy to bleed the system but if you have a tiny radiator leak (at the each crimped end) then you will have to fix that first otherwise you are wasting your time bleeding.
I would recommend not troubleshooting your heater core. Never heard of a G or Z that needed to get that replaced.
Old Oct 11, 2013 | 10:59 AM
OnlyGoWOT's Avatar
Also to answer whether or not I've had recent coolant work done. I just recently purchased it from an Infiniti dealer with 55k miles.
Old Oct 12, 2013 | 01:51 AM
Nate_6mt's Avatar
Originally Posted by srv2nv
If you need to ask, then you need to take it to a mechanic. :lol:
Bump... Lol
arora_g35
Apr 16, 2026 02:52 PM
Rokafor
Jul 29, 2015 11:50 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
vstypicals
Jul 20, 2015 10:55 PM
