2003 Sedan Rim size question
Old Oct 15, 2013 | 02:25 AM
Karl Horn's Avatar
Been looking on here and can't find a clean comparison between 18, 19, and 20 inch rims on our cars. I'm about to order a set but want to know how each size impacts the performance and/or handling. Let the debate begin
Old Oct 15, 2013 | 03:16 PM
Dr3w5ki's Avatar
20's on our cars are too big IMO.
I go with light weight 18's for performance/track oriented and 19's for looks. I think 19's look the best on our cars. Then again, there are some light weight 19's you could buy as well which is like a win-win situation.
Old Oct 15, 2013 | 03:55 PM
BazookaJoe's Avatar
19's look great for a modest drop or no drop at all.
20's look good slammed
18's are good from performance standpoint as they are lighter
No matter what size you go with there are a lot of different aspects to take into account.
When you start installing large rims with different offsets than stock you can run into problems. Research, research, research, then buy. Or you may end up buy a second set when your first set doesnt work like you thought it would. like I did
Remember Coupes and sedans have different offsets, so dont just go buy some wheels a guy had on his coupe g35 if you have a sedan they may not fit.
There is a lot of good wheel info on G35driver just do some searching.
Old Oct 15, 2013 | 06:27 PM
Mustang5L5's Avatar
Some practical things to consider.
Larger diameter wheels take more power to spin. So the larger you go in rim size, the slower the car will be. Not a dramatic difference, but it may be noticeable.
Larger diameter wheels usually run shorter sidewalks to meet original rolling diameter. Less rubber usually means crispier handling.
Less rubber also means firmer ride due to less sidewall. If you live where potholes are plentiful, this may be an issue.
Larger diameter wheels cost more money. Depending on brand and model tire you get, if they wear out frequently, tires could be a major and frequent expense.
My personal opinion is 18's overall fit the car well, 19" wheels can be done depending on what rim style and ride height. Not a fan of 20's personally
Old Oct 15, 2013 | 09:23 PM
Lartytiejdke3's Avatar
Pick either 18's or 19's depending on your plans for the car, and ensure they're made with quality. There is no debate here.
marsman328
Northern California
Aug 11, 2015 07:29 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
realtalk21
Jul 20, 2015 09:07 AM
