Help me find the rattle!
Old Feb 6, 2005 | 02:14 PM
mark5's Avatar
I cant find this damn rattle! I think its coming from the center where the clock is, or it might be from the window. Anyone else have this rattle?
Old Feb 6, 2005 | 02:33 PM
kona063's Avatar
I don't have any rattles [yet?!?] but I do have a serious 'creak' coming from the back of my G35x when I hit uneven pavement. I assume its coming from behind the seat and there is a bolt holding a crossmember that I can hit with locktite [sp?] but I don't want to pull the seats out until I have a better idea of what and where the problem is. I would appreciate any help you can provide on this issue as well.
Old Feb 6, 2005 | 03:24 PM
ABQ_G35's Avatar
Check under the driver seat, there is a duct there, mine had a wire resting on top of it.
Old Feb 7, 2005 | 01:00 AM
sickpig's Avatar
There is a TSB about a creaking or popping from the base of the windshield. Mine does it, especislly when cold.
Mark
Old Feb 7, 2005 | 01:04 AM
ndeans's Avatar
Try squeezing your mirror. If you have rear view mirror with the homelink it can buzz or rattle. Mine had that. I asked my dealer and they said they would take it apart and put some felt tape in between the plastic. Worked like a charm!
Old Feb 8, 2005 | 10:25 AM
mark5's Avatar
"There is a TSB about a creaking or popping from the base of the windshield. Mine does it, especislly when cold"
did you get it fixed?
Old Feb 8, 2005 | 11:04 AM
Dirtbag's Avatar
Here's the TSB regarding the rattle at the base of the windshield. Hope this helps. - Mike
Click here
Old Feb 8, 2005 | 11:39 AM
lawboy05's Avatar
sickpig...where can I find the TSB on the dash rattle?
lawboy05's Avatar
Oops...didn't read down far enough....thanks dirtbag
Old Feb 9, 2005 | 12:15 AM
subrobo's Avatar
check the air con place. sometimes those plastic makes noise! hope you know where im talking about
Old Feb 9, 2005 | 09:26 AM
Dirtbag's Avatar
No problem, anytime bro. - Mike
Old Feb 9, 2005 | 09:51 AM
lawboy05's Avatar
I pulled the TSB Mike and it sounds exactly like what I am experiencing around my windshiled/dash area. Hopefully, this will help the dealer locate this particular rattle.
On another note, I was very excited to discover yet another new rattle in the roof of my G, around the sunroof. This makes a total of 4 rattles and the car only has 1600 miles on it. This seems excessive.
Old Feb 9, 2005 | 10:47 AM
Andyl's Avatar
Cheak the top of the batt cvr I put in my grounding kit and had a noise that drove me nuts and the dealership took off the top and it went away so I rerouted the wire and put the top back on and nomore noise
cmesidewayz
Sep 29, 2015 09:28 PM
jbmw002
Sep 3, 2015 08:42 PM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
