04 g35x please help
Old Mar 12, 2014 | 06:17 PM
inked05's Avatar
04 g35x please help
I own a 04 g35 x with 165,000 and my abs light vdc light and slip light are all on at the same time,i checked the brake fluid and its full. there is a spinning noise near the master cylinder whats is the cause ? https://g35driver.com/forums/images/.../confused2.gif
Old Mar 12, 2014 | 08:14 PM
5150DS's Avatar
This happened when I got a flat (about 70k) and not since (185k). I believe the rotating diameter of the flat tire wasnt the same as the full ones. Check to make sure your tires are properly inflated.
Old Mar 12, 2014 | 08:33 PM
inked05's Avatar
ok thanks ...the tire pressure light did come on shortly afterwards...I will add air tosee if it fixes the problem
Old Mar 12, 2014 | 10:44 PM
Mustang5L5's Avatar
A fault with a wheel sensor, or something in the ABS system would cause those lights to come on. The VDC/ABS operates by controlling each individual brake, so the ABS system needs to be in working condition.
Easy answer is to hope a tire is VERY underfilled to cause a rolling distance error. Next, id make sure all your tires sizes are the same.
Beyond that, there could be an issue with the ABS system which would require someone taking a look at the car
Old Mar 13, 2014 | 05:36 AM
inked05's Avatar
Thanks mustang
Old Mar 14, 2014 | 03:07 AM
epborden's Avatar
Originally Posted by inked05
Thanks mustang
Get your codes read at any auto parts store. Google those codes. Shot in the dark it could be a cam sensor.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
Claudiu
Sep 26, 2015 01:04 PM
