Mar 26, 2014 | 11:26 AM
Hi guys , i have a 03 g35 sedan with 203k miles . Im going to do the oil change soon but i dont know what oil to use because of the high mileage ..? I will apreciate any recomendations Thank u
Reply 0
Mar 27, 2014 | 08:23 AM
Castrol Syntec
Reply 0
Mar 27, 2014 | 09:30 PM
Does your car burn oil? If so, how much? If 1 qt or more in 3k miles i woukd go with name brand dino oil and change it every 3k miles. If less than a qt every 5k miles i would go with castrol syntec, mobil 1 or penzoil platinum. I would stick with purolator, bosch, wix, mobil 1, napa or k&n oil filters. Notice no Fram, they have a questionable reputation for build quality. As for weight, 5w30 if not burning much oil; 10w40 if burning more than a quart.
Reply 1
Mar 27, 2014 | 09:34 PM
Quote: Does your car burn oil? If so, how much? If 1 qt or more in 3k miles i woukd go with name brand dino oil and change it every 3k miles. If less than a qt every 5k miles i would go with castrol syntec, mobil 1 or penzoil platinum. I would stick with purolator, bosch, wix, mobil 1, napa or k&n oil filters. Notice no Fram, they have a questionable reputation for build quality. As for weight, 5w30 if not burning much oil; 10w40 if burning more than a quart.
Perfect recommendation. I am partial to using a Factory Oil Filter....
Reply 0
Mar 27, 2014 | 09:39 PM
The factory filters are great quality. Don't doubt them .
Reply 0
Mar 27, 2014 | 10:16 PM
Hello , i just bought the car when i did the oil change it was only half a quarter low , its my first car and i love the g , can i put the 0-40w my only concern is the oil pressure caz my seals probably there not that good caz of the mileage
Reply 0
Mar 28, 2014 | 06:55 AM
The Mobil1 0w40 is a great oil and the only true synthetic mobil1 sells in the us, I would go with it. The 0w40 tends to be thinner than a normal 40 weight so if you burn more then try 10w40.
Reply 0
