Rear License Plate screws won't come out
Old May 28, 2014 | 12:25 PM
Mustang5L5's Avatar
So i haven't touched my rear plate in about 2 years. Today, i went to remove it to swap it to another car and the darn screws are frozen in place.
I even swapped them to stainless steel screws to avoid this problem. Guess the salt can't be stopped.
I currently have the screws soaking in penetrating fluid and will keep applying and trying until I can get them out.
Has anyone ever dealt with this? In the case I decide to snap or drill the heads off, can the bracket be replaced easily or does the bumper need to come off?
What a PITA.
Old May 28, 2014 | 12:35 PM
Urbanengineer's Avatar
It's those weird clips that hold the plate on behind it. I made sure to douse my new bolts in never cease.
Old Oct 13, 2014 | 07:31 PM
Mustang5L5's Avatar
Ok bump on this. I have a vanity plate on my car I really need to transfer and can't get it off!
To the FSM I go.
Old Oct 14, 2014 | 06:49 PM
skippyG's Avatar
Mine has plastic backers... One of mine came loose and I had to reach around underneath the bumper & hold it to get the screw threaded. Wasn't hard to reach though.
Old Oct 23, 2014 | 08:55 AM
Gomer's Avatar
I had the metal clips on the back and they were fused to the bolt due to road salt. I took a Dremel and sanded the had of the nut off.......5 mins plate off.
Old Oct 23, 2014 | 09:12 AM
Mustang5L5's Avatar
Ok, but after I get the plate off, i need to put another back on. Did you replace the bracket? Where did you get a new one?
Old Oct 23, 2014 | 11:33 AM
skippyG's Avatar
If I'm getting what you're trying to do...You could just replace the bolt that goes through the bumper & back it with a nut & a good sized washer.
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
crazy_g35s
Jul 20, 2015 02:30 PM
