Rough Idle on my '05 G35
Old Dec 24, 2021 | 12:49 PM
  #46
Trouble131's Avatar
Putting together G35 Infiniti first time fun so far
My bad but im saying if there is oil on the sparks or in the hoses what should I do or what could it be ?
Old Dec 24, 2021 | 01:41 PM
  #47
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If the well tube oil seals fail it can fill up the spark plug well tube with oil and cause a misfire, fairly common with higher mileage.
Visually inspecting the spark plugs for color and gap can tell you which cylinder is misfiring, unless it's throwing a code for an exact cylinder misfire this is by FAR the easiest way to tell which cylinder is the culprit. Compare all 6 spark plugs and it's usually obvious which one is the problem child.
Old Dec 24, 2021 | 01:44 PM
  #48
Trouble131's Avatar
Not a misfire its no oil or none they good I found the issue its my intake timing solenoid
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Rehman2009
Jul 27, 2015 03:23 AM
laksjd84
Jul 24, 2015 05:12 PM
