Driver's Seat Replacement
Old Dec 30, 2014 | 03:57 PM
acraigl's Avatar
Hi,
I need to replace my driver's seat in my 2004 G35x Sedan. Specifically, I only need to replace the backrest portion. Would I need to remove the whole seat to do so? Any other things I need to do? (i.e. disconnect harnesses/battery, etc)?
Any online guides for this? Thanks for the advice!
Old Dec 30, 2014 | 04:50 PM
Frankieg35's Avatar
Disconnect the battery because you will be disconnecting the airbag harness and take the seat out
Old Dec 30, 2014 | 08:17 PM
acraigl's Avatar
So, no way to do just the backrest? I need to remove the entire seat?
Old Dec 30, 2014 | 08:27 PM
Urbanengineer's Avatar
It's literally four bolts and a clip connector at the bottom of the seat. I remove them any time I do any work in the back area of the car.
Old Dec 30, 2014 | 08:58 PM
acraigl's Avatar
Sounds simple enough. Thank you.
Old Jan 18, 2015 | 10:13 AM
acraigl's Avatar
A bit of a follow up question... I got a replacement upper seat and now that I look at it, it would seem much simpler to switch out damaged the leather covering, rather than dismantle the entire seat. The only issue is that I can't figure out how to remove the lumbar lever and the two plastic caps for the headrest.
Is there some secret to this (assuming it's possible)?
EDIT: After a little more playing, it looks like the cover might actually just stretch over and then fit behind these elements. Is that the right approach?
si_driver
Interior
Jul 25, 2015 09:22 AM
vstypicals
Jul 20, 2015 10:55 PM
realtalk21
Jul 20, 2015 09:07 AM
si_driver
Jul 16, 2015 09:40 PM
