Need help finding specific rotor size
Old Mar 4, 2015 | 09:26 PM
BroskyBoy15's Avatar
So I recently bought the two front rotors for my G35 2003 Sedan, but apparently my car had aftermarket rotors and the ones I received from autoanything.com had them made specifically as stock specifications.
The ones I received are Front Brake Rotor Diam x Thickness (in):11.7 x 0.9 so they are a bit smaller than my current ones. The problem is my calipers don't work with the new ones I received.
Here's a picture of my current rotors 13 Inches Height x 22mm Thickness
I need help searching for rotors that fit my current specs.(13 inches height x 22mm thickness)
Old Mar 5, 2015 | 08:38 AM
Mustang5L5's Avatar
A photo of your brake setup including the calipers would be a lot more helpful in identifying which brake rotors you need to buy vs a photo of the actual rotor.
I could make some suggestions, but seeing the caliper would be a lot more helpful than just guessing that someone installed different brakes.
The 11.7" rotors are correct for a stock 2003 sedan.
2005+ used 12.6" front rotors, and the 2003-2004 Brembo's off the coupe are 13". I'm guessing these are what you have, but also would expect you would have realized this??
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
