Power loss after cleaning TB
Old Mar 16, 2015 | 02:21 PM
korfak's Avatar
Hi, the mechanic clean the TB as a part of a maintenance process, after that, I have no obvious problems like rough idle or something like that, but when you push the throttle full, the car doesn't have the same power at all.
I clean the Maf, check for leak, and nothing
The only thing i found is 2 cel codes
P1273 (Af sensor on bank1) and P0328 (Knock Sensor)
Old Mar 16, 2015 | 05:40 PM
maxxcool's Avatar
ouch. sounds like the mechanic did not know to reset/relearn.
http://www.nicoclub.com/archives/g35...-learning.html
you need to relearn the ecu \ throttle and idle air. this needs to be done every time you touch the maf\throttle body. I would find a new mechanic as well.
Old Mar 17, 2015 | 12:25 PM
korfak's Avatar
Without the relearning it makes sense that those cel appear??
Ill try one more time to relearn but I previously try and it doesnt work, maybe im doing it wrong
I even take out the battery from a entire day, im not sure if that help too
Old Jul 15, 2015 | 06:41 PM
korfak's Avatar
I Know this thread is old, but as a feedback, the problem was the Knock Sensor, for a reason it fails to work just when the mechanic clean the TB, just replace the knock sensor and everything goes back to normal. Huge power loss, no visible Code.
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
