I need help on a/c sensor I don't know where to buy it online?
Old May 6, 2015 | 06:21 PM
Markjay2708's Avatar
Need help finding the part online I don't know what's it called I sort of ripped it apart while replacing to new radiator. Now my A/c blows hot air.
Old May 6, 2015 | 07:47 PM
mushu's Avatar
Here is a diagram. Hope it helps. http://orderinfinitiparts.com/parts/...iagram=3840050
It looks like a pressure sensor on the condenser. The part I saw are kind of pricey cuz it's a part of the condenser. If I were you I would take out the part and maybe look at a junkyard for a replacement. Be careful taking it out though because I think it's pressurized. Hope this helps. Good luck!
Old May 7, 2015 | 09:50 AM
Thanks a lot I just order the parts. Turns out to be the a/c switch.
Old May 7, 2015 | 06:05 PM
Mustang5L5's Avatar
That's the refrigerant pressure switch. It detects high and low pressure situations and can shut off the A/C
In order to replace it, you need to evacuate the system's refrigerant, replace the switch, and then recharge the system.
Easy fix if you have the means to discharge and recharge A/C refrigerant.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
champppy
Mar 31, 2020 12:25 PM
Phenomenon9
Aug 9, 2015 01:34 AM
KevinnnVo
Jul 28, 2015 06:29 PM
