2005 G35x Manu-matic Working Intermittently
Old Jun 4, 2015 | 11:10 AM
Georgek99's Avatar
For the last few months I've had an issue with the manual shifting on my auto trans. Seems like when it's hot, it doesn't allow me to shift manually.
Thoughts? It's a 2005 G35x with about 133K miles on it.
Thanks,
George
Old Jun 4, 2015 | 12:50 PM
WhosUrBuddiee's Avatar
Then dont use the manu-matic.
Old Jun 4, 2015 | 04:52 PM
maxxcool's Avatar
Thanks,
George
Take her to the dealer. there are a number of points that break and wear in the manual shifting. you'd need to be a expert multimeter user and have a very good idea on reading schematics to resolve it on your own.
Old Jun 6, 2015 | 02:50 PM
superman22x's Avatar
Check your codes. I have the same issue, the manual mode is intermittent. I had a check engine light checked at some point and there was another code for a switch that seemed to be related to the manual mode shifting. I never actually looked into fixing it. But I think replacing the shifter assembly might be the solution.
Old Jun 8, 2015 | 02:09 PM
Georgek99's Avatar
Sounds like the suggestion of not using it is gonna be the most economical. I'm sure the stealership would love to throw some billable hours on the diagnosis and fix.
Old Jun 9, 2015 | 12:15 PM
Mustang5L5's Avatar
Odds are it's the shifter unit itself. If you are good with a multimeter you can troubleshoot it, but it will be a little tedious to trace out wires and test.
If you can get a shifter unit for cheap (junkyard or ebay) i'd try swapping it out. Most of the times, when guys post about manumatic issues here, it's a shifter issue.
Personally I never use the flipping thing. No Clutch...no Care.
mike730
Jan 12, 2018 04:25 PM
trulegend
Audio/Video/Electronics
Jul 31, 2015 03:37 PM
socalg35x
Jul 28, 2015 10:42 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
attarday
Jul 15, 2015 04:03 PM
