Do you feel the G35 has enough low end torque?
Can you break the tires loose from a dead stop in a AT?
Does the car have traction control to prevent wheelspin?
What mods will give you a little more low end?
From the loaners I have driven, there is PLENTY of torque in the AT. Its feels like it has more than my 6mt.
Quote:
Yep, but I could always use more Originally Posted by harley01
Turn off the VDC, foot on brake, push gas down and release brake quickly (flash stal the torque converter), go full on WOT and you can smoke them through 1st and into 2nd sometimes.Can you break the tires loose from a dead stop in a AT?
Yes, and it would be nice to completely turn it off, but you can't unless you remove the ABS fuse.Does the car have traction control to prevent wheelspin?
Higher stall torque converter, Roots-style supercharger, shorter tires, nitrous.What mods will give you a little more low end?
my 5AT catches second and third gear on the street
it has a lot of torque. it will smoke the tires all the way through first unless i have people with me
