DIY for replacing oil pump?
Old Jun 12, 2015 | 08:21 PM
JRandallC's Avatar
There has been a high-pitched whining sound coming from the engine lately on my son's 2003 G35 Sedan. I poked around and narrowed it down to the oil pan, which led me to believe it was a faulty oil pump on its way out. Today I dropped to oil pan to put in a new oil pump....wow! That's not a plug-and-play job. It's a lot different than other oil pumps I have replaced. So, a couple of questions...
1. Is there a DIY on replacing the oil pump? I couldn't find one in the DIY video section, nor on YouTube.
2. Is there another potential cause of a high-pitched whining sound that seems to be coming from the oil pan? It seems to come and go (I don't drive it daily to have a good sense of how often the sound is there).
Old Jun 13, 2015 | 10:21 AM
herrschaft's Avatar
Probably not since most people wouldn't have the means to replace it themselves. But here's the FSM: http://psedog.com/cars/fsm/g35/coupe/2006/lu.pdf
Old Jun 15, 2015 | 09:17 AM
Mustang5L5's Avatar
Agreed. Not a common issue here, and many don't have the means to tackle it. You might have to be the first one to do it and write a DIY
Old Jun 15, 2015 | 09:15 PM
markc's Avatar
From what I see in the FSM, that would be a major undertaking. Also gleaned from the manual is that the pump is mounted on the front side of the crank shaft and not in the oil pan. Could the noise be from some other rotating piece?
Old Jun 15, 2015 | 11:36 PM
coffeysm's Avatar
When I had a high pitched whining noise it was the bearings in my water pump. The pump is driven by the chain, so that might be what you're hearing?
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Jussaku
Aug 4, 2015 12:45 PM
newg37
Jul 26, 2015 09:32 AM
