AC belt change
Old May 28, 2016 | 11:30 AM
m17davis's Avatar
AC belt change
So I bought the car without a AC belt on. So I went to put a new one on and the nut is stripped on the pulley. Is there anyway around this?
Old May 30, 2016 | 08:22 PM
JoshuaDunand's Avatar
The nut is stripped or the treads are stripped?? If the threads are stripped you could most likely re-tap them or have someone re-tap them for you. If the nut is stripped you either need to find the best locking pliers you have or risk hammering an old socket on the nut. Or pay your mechanic to do it and sit back and enjoy your weekend
Old May 31, 2016 | 09:44 AM
Mustang5L5's Avatar
Hopefully you can get a good bite
Old May 31, 2016 | 10:24 AM
LoSt180's Avatar
Well, that explains why there's no belt.
Is this the nut for the idler pulley? I'd go ahead and order a replacement pulley and swap it out. You can get the current one loose with some vice grips on the nut.
Jordanbid916
Jun 16, 2016 02:13 PM
04bs6mt
Jun 12, 2016 08:48 AM
edwinisdumb15
SOCAL Meetings & Events
May 25, 2016 05:39 PM
edwinisdumb15
Apr 30, 2016 07:31 PM
