Turbo Charging a 04 g35x AWD sedan
Old Sep 7, 2016 | 10:54 PM
Infiniti_G35x's Avatar
Whats up guys im just toying with the idea but if i wanted to throw a turbo in my car would it be plausible? i intend on getting larger injectors and fuel pump an ECU Reflash programmer. Here is the list of stuff i found on ebay please let me know your input. thank you!
Turbo Kit (with intercooler)
http://www.ebay.com/itm/252392597549
630cc fuel injectors
http://www.ebay.com/itm/281434883320
255 LPH Fuel PUmp
http://www.ebay.com/itm/191413376456
HYPERTECH MAX ENERGY SPORT TUNER ECU REFLASH PROGRAMMER
http://www.ebay.com/itm/252513256958
Im kinda new when it comes to putting aftermarket parts in cars, i would be paying a garage to install the items, and would probably have to bring it some where special to be tuned. THanks for any input have a good one guys
Old Sep 8, 2016 | 03:19 AM
Blue Dream's Avatar
I drove ttrank's car solo
In order to be a successful forced induction owner it's my belief you need to have 2 things.
1. A ton of knowledge about what you're planning
2. Very deep pockets
You're on the right track for the beginning stage of a build by doing research and asking questions but my advice is to pause a bit and spend a LOT of time in the Forced Induction sub forum here, and better yet the same sf over on my350z.com, to read up and educate yourself on exactly what you're getting into here. The prevailing belief is to do it right you'll be spending over $10K so 1 initial question you will have to answer for yourself is "Is it worth spending more on my build than my car is worth?". It isn't as easy as buying a cheap eBay no name turbo, a few accessories and a questionable tune thinking you've done it right. Not even close.........
Old Sep 8, 2016 | 11:16 AM
Mignav01's Avatar
If you plan on going turbo you're gonna need a built block, unless you're staying under/at 400 whp, and if that's all you're shooting for than you might as well go sc.
Like blue said is it worth it to you? A built block + turbo kit installed yourself will probably run around 15k at least, not counting a tune. At that price + trade in you could probably pick up a car that has around that much HP stock... so I'd spend quite a bit of time thinking on it.
With that said, I also agree with blue, go to the other 350 site, much more hardcore in terms of performance mods and their subforum for FI is quite substantial.
Best of luck, post up some pics if you go through with it
Old Sep 8, 2016 | 10:38 PM
Thanks for the input guys i think you put things into perspective for me, my pockets are not that deep so ill probably stay away from the forced induction for the time being.
Old Sep 8, 2016 | 10:58 PM
Blue Dream's Avatar
Trust me when I really want something I will make poor decisions at times based on emotion then regret them later.
Your decision=win (as much as it might suck)
Old Sep 14, 2016 | 02:41 PM
Mustang5L5's Avatar
I'm not sure I'd put a lot of faith into an Ebay turbo kit as well.
Had I kept my car.....LSx swap
Project-G
Accessories
95
Jun 26, 2017 02:28 PM
formulag35
Steering & Suspension
Sep 13, 2016 12:40 AM
ScraggleRock
Aug 18, 2016 01:11 PM
Kevin Alvidrez
Aug 11, 2016 11:07 AM
AckG
Aug 9, 2016 08:24 PM
