AWD / X owners and Test Pipe help needed.
Old Sep 29, 2016 | 06:08 PM
Danielek's Avatar
Hello G35X owners.
I hope someone can answer this silly question. I am contemplating on installing test pipes on 2005 with AWD and have researched this site and vendors but there isn't much on here for the guys/girls that own a AWD model in regards to why certain test pipes WILL NOT FIT AWD model?
I looked under the car and the Transfer Case is mounted further back in the center between the Y pipe space so i don't really understand why any type of a Test PIPE would not fit an AWD model when the cats are located not even close the where the TC case and there appears to be a plenety of room.
Can any of the AWD owners confirm or deny that a test pipe they bought would not fit and why? And which test pipes they have used? I am looking at the resonated once.
Your expertise and advise be much appreciated.
Have a good day everyone.
Dan
Old Sep 30, 2016 | 10:59 AM
danoman32's Avatar
Test pipes shouldn't be a problem. Where did you read or hear that you couldn't use test pipes on an X? Y pipe is usually the problem.
Old Sep 30, 2016 | 11:34 AM
Danielek's Avatar
Been looking on line Ebay, etc and some ads say that WILL NOT FIT X Sedan.
Which one would you recommend to get for 2005X? Resonated be better then?
Were you able to shut off CEL with the anti-fouler trick fix for 2005?
Nick_M
Engine - Intake/Fuel
Aug 27, 2016 01:56 AM
Tuner
Engine - Power Adders
Jul 25, 2016 01:28 AM
xWKUJoBo36x
Engine - Exhaust
Jul 7, 2016 11:25 AM
nickg93
Jul 6, 2016 08:55 PM
