Whinning steering pump
Old Jan 20, 2017 | 04:46 AM
neo_anderson302's Avatar
I have a 04' sedan manual. Yesterday after changing brakes and rotors I noticed a new sound. Seems like the steering pump. I checked the belts and the sound still lingered. It would go away and then come back. I check the fluid and it was cold max @ 40 degrees. I did turn the wheel a few times with the car off. My friend said maybe I have air in there because the car was off. Anyone have this problem?
Thank you!
Old Jan 20, 2017 | 12:34 PM
Mustang5L5's Avatar
Jack up front of car so that wheels are off the ground. With engine off, turn the wheel lock to lock a few times to flush any air out.
If that doesn't work, look into a fluid flush, but you may need to replace that pump if those two tricks don't work
Old Jan 22, 2017 | 11:22 PM
ok Thank you
Will give both a shot!
