Puerto Rico
Old May 10, 2017 | 07:28 AM
ecrespo's Avatar
Puerto Rico
I have a 2005 G35 coupe that has a over temp problem. The over temp has rise the pressure in the radiator and it break. A new radiator was installed but still the same problem. Any possible solution?
Old May 10, 2017 | 08:23 AM
eazdaskeez's Avatar
Did you bleed the system? Compression test?
Old May 11, 2017 | 02:13 AM
NjMatteSedan's Avatar
maybe the thermostat is stuck closed and needs to be replaced
Old May 11, 2017 | 06:23 PM
kdude63's Avatar
For overheating when it was previously operating fine, it's likely the thermostat stuck closed.
If the pressure in the radiator rose higher than it was supposed to, that's the radiator cap.
If overheating caused the pressure to rise higher than it was supposed to, replace both.
Element G35
Jul 16, 2010 09:12 AM
PRG35
Nov 8, 2009 11:33 PM
IS300TOG35
Mar 23, 2006 02:12 AM
