Replace stock resonator with 6" x 14"
I want to replace the stock resonator but it must be stainless steel. Magnaflow has a 6" x 14" 2.5" inlet (round body) I am wondering if this will fit ok or will it bang on the heat shield because it is 6" in diameter? There is also a 4" x 14 2.5" but might be a little small. What would be the difference in sound between a 4" and 6" muffler?
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
The OEM stock Coupe middy w/resonator (fits sedan perfect) dimentions are very close, if not the same, as the Mag. So, all that being said, if ya wanna spend the extra money ....cool beans. Your question about the heat shied is valid BUT, not a problem. The heat shield is the same gage as frigg'n tin foil, so it can be bent to whatever degree you wish. Or you can do what I did and take your Dremmel tool ( with cutting wheel attached) underneath the car and route out that 2" or 3" small contact area in about 10 seconds. Then you too can impress friends and relatives with how **** you are. LOL
JBX By the way....you'll gain little (just a few throaty dbs.) in the sound dept. with just this mod. alone...........
noper......ya gotta change the end pipe/muffler (Stillen SS single is $319.)to get any more. And, if ya got a 2wd sedan ....the Y pipe will complete the pkg.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
