Output shaft (Axle) seals front and rear part numbers
Old May 9, 2018 | 11:52 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
I have been searching and can't find anyone that has listed any front and rear output shaft seal part #'s for the G35X. The rears should be the same as the regular G's. Does anyone know of a thread consolidating part numbers for bushings and seals? If not I'll start something as I build the 05' as I'm disassembling the car now so I can replace all of the normal 150k+ maintenance crap. It would be very helpful to have aftermarket PN's so anyone could look them up here and walk into oreilly,autozone,napa,etc....
Edit: So far I have found
Front carrier
Driver side outter O-ring PN 38343AR000 <-- Not the correct seal for outter edge of final drive sealing into oil pan. Ordering 383430P013 next
Driver side inner seal PN 402270P001
Passenger side seal PN 3834203V01
Driver side oil pan front axle seal - 402270P002
Transfer Case
Rear output seal PN 3314201J10 or 710916 (National)
Front output seal PN 710722 (National)
Rear differential
Left/Right seal PN 38342p9010
obender66
Drivetrain
Feb 25, 2015 10:13 PM
studio54
Jan 17, 2014 02:32 PM
SlickSilverG
May 29, 2010 11:05 AM
voltagefx
Oct 16, 2009 12:02 PM
