JDM and USDM transmissions??
Old Oct 30, 2018 | 05:08 PM
Raul Cortez's Avatar
I currently have a USDM 05 G35 Sedan RWD 5AT and looking to buy another transmission. I've found plenty of JDM transmissions for 03-05 but will they bolt right up or will I need other parts and sensors?
Old Oct 30, 2018 | 05:43 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
They're the same, there was a single MAJOR revision in the transmission which relocated the TCM into the transmission instead of being next to the ECM. You can tell them apart because the early model external TCM tranny had 3 bundles of wires with green harnesses coming out of it and the newer internal TCM ones have a single large grey connector at the grommet where the other wires came out of the tranny.
You can still swap the TCM and valve bodies between the two, so if you buy the wrong one you can take your existing TCM and wiring harness and swap it.
rinox
Apr 1, 2008 10:14 PM
Predator
Mar 27, 2007 05:20 AM
WhiteonWheat
Mar 1, 2006 12:44 AM
Malone04 G35
Nov 18, 2005 04:04 PM
