Headlights and blinkers not working
Old Dec 25, 2018 | 12:47 PM
odomfl's Avatar
G35 Base
2005 G35 Base Sedan. Headlights and blinkers not working after removing the instrument cluster to repair the fuel gauge. I have checked all the fuses and rechecked all the connections and even replaced the switch; still nothing. Any help would be greatly appreciated.
Old Dec 25, 2018 | 01:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I can practically guarantee you didn't plug in the turn signal switch properly when you reassembled the column. You removed it when you took the cluster out.
If you did this work with the battery still plugged in then you might have fried something else.
Chris Bulman
May 15, 2018 03:35 PM
Javi Fuentes
Nov 21, 2014 01:33 PM
BowWizzel
Lights
Jan 10, 2013 11:08 PM
mellinox
Aug 8, 2010 06:16 PM
jasijay
May 14, 2004 01:48 PM
