Window Relay location
Old May 26, 2019 | 05:14 PM
h8haters's Avatar
G35X
Can anyone plz help me locating Infiniti G35x 2005 Sedan Window Relay location?
Old May 26, 2019 | 05:22 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There isn't one. The window up/down buttons are a serial link to the BCM which processes and sends the data via CAN to the switch CPU located inside the same enclosure as the button for that window. The CPU process CAN and actuates the motor directly, no serviceable relays.
What exactly is the window doing? If it's not working then unplug the harness from the motor, stick DMM probes into the two harness pins, and check for voltage. You should have have battery voltage present when the button is pressed, it switches polarity for up/down operation. If you do NOT have voltage present when the switch is being operated then you need to troubleshoot the switch or sub-switch (driver side is the primary switch, passenger side is sub-switch).
COBB 30066
Dec 13, 2017 11:52 AM
midnytegsedan
May 23, 2017 01:45 AM
JPM8806
Nov 4, 2009 12:03 PM
anadich961
Apr 26, 2009 10:47 AM
rocsell
Sep 19, 2007 11:22 PM
