How an Automatic Transmission Works - Full teardown
Old Sep 16, 2019 | 08:53 PM
speedkar9's Avatar
Infiniti G35
Here's what's inside an automatic transmission and how it works!
This transmission is from the RWD G35. All of its internal components are located along one axis, with no countershafts, since this is mounted longitudinally.
This is the transmission pump:
The first planetary gear set on the input shaft:
The first two sun gears:
The clutch packs that lock up the gear sets:
The brain (valve body), computer and solenoids that control hydraulic flow to the clutches:
This is the output shaft with the lock gear that the pawl locks into when you put it into park:
And that's pretty much all the components in an automatic transmission!
Enjoy!
Old Sep 17, 2019 | 01:05 PM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
Very nice work. I really enjoy these tear-down threads of yours. The pictorial information is very valuable reference.
Old Sep 17, 2019 | 06:56 PM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
Cool to see the 03' transmission apart. I haven't seen the external TCM valvebody until now. Nice to know they used aluminum high drums from the start also.
Thanks!
Old Sep 17, 2019 | 09:29 PM
speedkar9's Avatar
Infiniti G35
Thanks, glad you enjoy them. The video is much more detailed with explanation too.
Thanks!
Yep! This one is actually a 2004 G35, but same deal. I was surprised at the electronics in the valve body too - all the solenoids are easy to access from underneath the car.
Old Sep 18, 2019 | 12:11 PM
I forgot the 04' RWD cars came with external TCM and narrow band upstream O2's. The 04' G35x got all the newer stuff. (widebands and internal TCM)
AmateuRN
Picture Share
49
May 27, 2011 02:19 AM
b2autodesigns
Event Photos
Nov 24, 2009 09:59 AM
suby01
Media Share V36 Sedan
19
Nov 5, 2009 11:47 AM
Royal_T
Picture Share
Oct 26, 2009 03:09 AM
ILLicit
Picture Share
16
Aug 5, 2008 02:28 PM
