2003 G35 sedan
Old Jun 30, 2020 | 12:52 PM
teemason's Avatar
G35 Sedan
2003 G35 sedan
Can someone help me with a tuneup? I need to know the parts involved in a tuneup? 2003 G35 Sedan. Thanks 🙏🏾
Old Jul 1, 2020 | 11:49 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Basic parts/services I'd consider for a G35 'tuneup':
-Oil + oil filter (I'd recommend getting a synthetic 5w-30 or 10w-30. VQ's are hard on oil and tend to burn some)
-air filter (inspect your intake couplers, as they tend to crack with age/miles)
-spark plugs (I oem NGK PLFR5A-11, some recommend going one step colder with mods. I have a set, going to try them out soon)
-PCV valve (inspect your pcv hoses, they can become brittle and crack)
-Check for leaks (power steering, coolant, ATF, engine oil,)
-Transmission fluid service (~4qts per service if you are a 5AT. many recommend you do a few drain/refills vs. getting a flush). OEM fluid is Nissan 'Matic-S' and 'Matic-J' (discontinued), one suitable replacement I'm using is Idemitsu 'Type-J'. Almost a year on the fluid and no problems.
-Diff fluid service
-Replace/flush coolant. Note: these cars are challenging to bleed air out of the cooling system.
Check over your suspension and driveline components/bushings for wear and tear. Lower control arm bushings are a known failure point on these cars, and lower ball joint boots tend to tear.
Old Jul 10, 2020 | 04:57 PM
srv2nv's Avatar
G35 Sport
I would also add a MAF sensor cleaning, and if its dirty, a throttle body cleaning as well.
Old Jul 12, 2020 | 02:04 PM
teemason's Avatar
G35 Sedan
I changed out spark plugs and coils. The service engine soon light is on. I did notice a little oil on 2 spark plugs one on each side. Any suggestions on that light?
Old Jul 12, 2020 | 04:06 PM
04.5 G35 Sedan 5AT
Did you pull the codes?
Old Jul 14, 2020 | 11:48 AM
teemason's Avatar
G35 Sedan
Codes were pulled it showed bank 1 #2 sensor was bad. I may just replace all if the job isn't too bad. Thoughts?
Old Jul 17, 2020 | 05:12 PM
srv2nv's Avatar
G35 Sport
I would check all your connections under the hood. Could be a vacuum leak causing the code.
SuperMike242
Jan 21, 2013 07:34 PM
G Thang Driver
Archived Sales
Apr 25, 2010 12:14 PM
