Intermittent Start
Old May 22, 2023 | 06:04 PM
atentaten's Avatar
G35 Sedan Manual
Intermittent Start
The car cranks and starts sometimes, the other times it will not crank. It will always crank when jumped.
The battery was swapped for a new battery while looking into this problem.
I was able to sit in the car and deliberately start it, turn it off and start it again until it didn't want to start anymore.
I noticed that when it did start, I heard the starter and/or ignition relays clicking. When it did not start, I heard nothing.
I've cleaned battery contacts and retightened them also replaced the metal connector that goes from the positive battery terminal to the fusible link.
Any ideas?
2004 G35 Manual Transmission.
Old May 23, 2023 | 03:52 PM
coffeysm's Avatar
Check the connections on the starter and the cable from the battery to the starter for corrosion.
Old May 26, 2023 | 08:46 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If it only happens when the ENGINE IS HOT but will start again once the engine has cooled down then it's usually the starter. Starter solenoids fail like that when they age, heat soaked and they won't work until they cool off.
Old May 29, 2023 | 05:03 PM
atentaten's Avatar
G35 Sedan Manual
Problem Solved
Here's the update. The problem was the starter. It bench tested fine when under no load, but would not start when connected to the gears. I also extended the the electrical lines from under the car and connected the starter, but without and connecting it to the gears and it would work like that too. Before doing any of that I tested voltage across both starter terminals and ground and got proper voltage. I figured the starter motor was too rigid to turn the flywheel, but would rotate when there was no load. Got a remanufactured starter from autozone, installed it and it fired right up. This was the first time I saw a starter that benched tested ok, but would not work when connected to the flywheel.
Old May 29, 2023 | 05:22 PM
cleric670's Avatar
BANNED!!!
Glad you got it all sorted out.
SugarShawn
Nov 24, 2014 04:31 PM
Mr. G
Nov 10, 2013 11:38 PM
khoacalacan
Sep 29, 2011 08:28 AM
ModMe
Jan 27, 2007 12:24 PM
