under body leaks
Old Apr 10, 2005 | 02:44 AM
ing35's Avatar
under body leaks
Recalling previous issue, I have run over some grease sort of stuff, thanks everyone..
Old Apr 10, 2005 | 08:03 AM
RichK's Avatar
Looks to me like someone got super sloppy with an oil change or 2. Do you change the oil yourself or does a mechanic/dealer do it? If you don't do it, tell the mechanics that their sloppy job is ruining your garage floor.
Old Apr 10, 2005 | 03:58 PM
ing35's Avatar
Richk, you are probobly right, I had a oild change performed by the dealer, but is it the engine oil had white stuff in it?? That is why I m so confused, please advise, thanks.
Old Apr 10, 2005 | 06:15 PM
Streaker's Avatar
Be very sure that your oil does not have white stuff or foam or anything else out of the ordinary in it. That would be a sure sign of contamination. If it's there and not corrected, engine failure could result.
Chuck
Old Apr 10, 2005 | 07:07 PM
Chico's Avatar
I don't want to sound mean....but what are you thinking asking for advise on a forum using pics???
The leak or whatever the problem is could be a thousand different things. Even the best and most experienced mechanic here will not be able to tell you with accuracy what it is.
Anything we say is just going to make your head spin and wonder all night. Take it to the dealer in the morning. I'm sure they will figure it out and fix the problem.
Good luck.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
