Easy oil changes...
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Originally Posted by spendgy
I don't think accessibility to the drain plug has ever been a concern. I believe the location of the oil filter in relation to the cover to be the most problematic.
oil changes
Originally Posted by callawayc7
I don't jack up my car either. Since my driveway (and i believe most people's driveways) slope slightly downward, I just move my car out of the garage half way. The front wheel is in the garage and the back wheels is in the driveway. That slight incline gives me enough room.
just my $.02 worth
being that the drain plug IS at the rear of the oil pan (and on a downward angle) I find that partially pulling up on my ramps a great advantage in getting ALL oil out. I also let the car "sit and drip" for quite a while before buttoning her back up.
The oil drain plug is at the rear of the sump. Putting the car on ramps will therefore aid in the draining process. If the drain were at the front of the sump, your argument would be valid.
Also, you have to be very careful with the height and incline of the ramps because the car is so low.
Lou
Lou
Originally Posted by XcarGO
This product has been around for quite some time, my concern is that you are taking what is the lowest point on your car and making it even lower, might it be possible that this valve assembly might be broken off if you drive over some road debris?
I do have to admit though, with 700 miles on my G I have yet to craw under it to take a closer look, but that will all change soon.
I agree that it is a excellent way to obtain mid-stream or occasional oil samples for analyst, but I don't feel comfortable having it installed. One smack of road debris or bottoming out, I feel it would take the brunt of the force and shear off the oil pan.
I have one fumuto valve with spring for sale
Just my .02 cents of opinion, nothing more, nothing less
Lou
Lou
Originally Posted by Jp1
I like the ramps idea but doesn't that make for a portion of the oil not being drained?? I thought at that angle there would be a portion of the oil/sump that wouldn't drain if only the front of the car was raised.... If I'm short on understanding...please fill in!
I believe the correct way to do it would be to get all four tires off the ground... this way if you're doing an oil change say... every 7k miles, then u can rotate the tires too (sedan) and inspect the differential fluid level and transmission fluid level (6mt models). Note however, if you extend drains past 3750 as stated in the manual, make sure you use a better filter. And I'm not just talking aftermarket, I mean a filter which is larger in diameter or length or or both. Equivalent filters (with same connections and thread) are Amsoil SDF-20 and Amsoil SDF-36. (the original is an SDF 13)
I'm not sure if the SDF-36 will actually fit (due to clearance issues), but if it will, its probably your best bet because you will increase your dirt holding capacity and increase your total oil capacity.
Does anyone know the best way to jack up the rear so jack stands can be thrown under the jack points?
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
