350z Rims on sedan... Where are the pics
Old Apr 26, 2005 | 01:34 PM
wanalaugh74's Avatar
I could have sworn that there were pics with the 350 rims on the sedan. Anyone seen them? If so , please post. TIA
Old Apr 26, 2005 | 01:51 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Pretty sure Z offsets won't work.
Coupe wheels will fit, but very close to max.
Old Apr 26, 2005 | 02:27 PM
THX723's Avatar
G Kreuzer
It depends on which Z wheel you're talking about and if you're sedan is lowered or not.
At stock ride height, the 17" Z wheels do fit, but the rear tires sticks out past the virtual fender-line plane by a few mm. That is nasty to me, but fine for some folks. The front is flush, so it looks fine. However, if you're sedan is lowered, the 17-inchers are perfect fit! That is in fact what I use for the track.
The 18" Z wheels (and Coupe wheels) have slightly less offset and makes for more 'stick out' than the 17" models at stock ride height. Again, not a pretty sight for my taste, but others think it looks aggressive. I didn't even think it would look good for a lowered Sedan, but I did witness someone at a local meet that was able to pull it off pretty good. His ride was lowered substantially and running a little more negative camber.
My best suggestion is to ask someone to let you put one on and see if you like how it looks.
Old Apr 26, 2005 | 04:23 PM
yea i dont really like the "sticking-out" of the rims. I just got the tokico d-specs with the Tein H Tech's and thought i would try some Z rims. i guess i'll just have to try it out.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
ResoG35Sedan
18 Inch
Nov 11, 2015 04:26 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
Gip
Aug 24, 2015 05:31 PM
linedr89
Aug 17, 2015 05:11 PM
