**Help** Swisscheese Mod gone bad
Old Jun 3, 2005 | 11:37 AM
ComptechRSX's Avatar
Hey guys i went to Swisscheese my airbox but i acutally did the Z tube insted and now my car runs like **** and sounds like my old chevelle when i start it. Now theres black smoke comming from the exhaust sometimes and the Cel wont go off. But i can still drive it if i keep it floored all the time. Should i get this checked out?
Old Jun 3, 2005 | 11:48 AM
QuadCam's Avatar
It sounds like you have an air leak between the MAss Airlfow sensor and the throttle body.
What you are describing happens to all Mass air cars if there is a large air leak.
Old Jun 3, 2005 | 11:50 AM
sickpig's Avatar
Just tell everyone it's a new diesel model. G35D
Mark
Old Jun 3, 2005 | 11:59 AM
DaveB's Avatar
Sounds to me like you didn't plug you MAF sensor plug back in and not all the way. Remove it, inspect the terminals, and try again.
A vacuum leak is another possibility, though the black smoke indicates a super rich fuel mixture which tells me the MAF isn't working right. Even without the MAF, the car will run, but will run badly.
If all else fails, take the Z pipe off and reinstall everything. Take your time and verify everything is secure, tight, and plugged in.
Old Jun 3, 2005 | 12:37 PM
GeeWillikers's Avatar
Walking The Fine Line...
Sounds like a loose nut behind the wheel..
No, it's perfectly normal behavior - why would you want to get it checked out?
(HellooOOOoooOOOoo??)
Old Jun 3, 2005 | 12:39 PM
G35_TX's Avatar
Have you guys ever read the RSX forums? The intellgence level on those forums are so bad its not even funny. This guy is bringing that here and you can obviously tell by his posts.
Old Jun 3, 2005 | 01:16 PM
dklau33's Avatar
When you say "Swisscheese" what do you mean by that? Did you poke a bunch of holes in your Z-tube or something?
Old Jun 3, 2005 | 01:21 PM
madchef's Avatar
If I am reading this correctly, it sounds like you put a bunch of holes in your Z-tube.
If this is true, then you need to stop driving the car until you can replace the z-tube (maybe put your stock air tube back in?). With these holes you are defeating the purpose of having an airbox all together, as who knows what you are letting into your engine!!
Any holes you make must be in the airflow path before the air passes through the filter. Good luck, and at the very least a throttle body cleaning is in order.
Old Jun 3, 2005 | 01:41 PM
madchef's Avatar
I'd also like to add that if you did drill holes in your z-tube that you really need to take the time to understand what you are doing before you do it.
You should have been asking yourself "if I am drilling holes in the z-tube, and the air is coming from the airbox+filter...why do I even need an airbox?"
Old Jun 3, 2005 | 01:57 PM
Msedanman's Avatar
O.F. Administrator
Don't drive it like that or you'll probably foul the O2 sensors, amongst other things. Fix the leaks and the airbox, check all connections and clamps and try again.
To reset the ECU CEL light, do a reset described in our DIY/FAQ.
If all else fails, have the dealer look at it.
G/L
C.
Old Jun 3, 2005 | 02:07 PM
Derzigster's Avatar
I can fix it with some Duct tape.
Old Jun 3, 2005 | 03:57 PM
DaveB's Avatar
I can't imagine someone would be stupid enough to drill holes in the Z pipe. I guess anything is possible.
Old Jun 3, 2005 | 04:05 PM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Trust me....if you read what he posted me.. you wouldn't ask about his level of competency or intelligence (MFAH !!!) The thread has to be a goof...nobody's that stupid. By the way Dave, thanx for the 'get back' and info. in the PM. JBX
Old Jun 3, 2005 | 05:43 PM
I think it acutally adds performace.. on my way home from a vacation in santa barbra i came up to a old looking yellow porsche and it said somthin on the back R.U.F or something and i florred it past him then he did then i did 3 honks and shat all over that thing. took it to about 130 had to slow down for a school zone. LAter
Old Jun 3, 2005 | 05:49 PM
MrBillMartin's Avatar
if you really want to get some air in there. get a "hoodspacer", and swiss cheese the pleneum too. youll see mad gains.
a ruf porsche. thats special edition from germany. Really Unbelivebly Fast.
btw you shouldn't drive fast in school zones, i think they double the points for the tickets.
goodluck with your cheese.
