Clock light and automatic shifter light not on
Old Jul 13, 2005 | 11:46 AM
G35Lakers's Avatar
I have a 2003.5 auto and the clock light and the P,N,D,R light by the automatic shifter doesn't turn on anymore. I checked the fuse box and none of the fuses are blown. I didn't see a fuse for the clock light either. Thanks for the help.
Old Jul 13, 2005 | 01:42 PM
Msedanman's Avatar
O.F. Administrator
....the bulbs are replaceable with minor teardown. Time to visit your dealer.
C.
Old Jul 13, 2005 | 04:08 PM
OG35's Avatar
My clock light is out as well and my warranty is expired. Does anyone know how much the dealer charges? Or do I even need to take it to the dealer? Is there an easy way to replace the bulb in the clock. Thanks for any help.
Old Dec 20, 2006 | 02:11 AM
RocketG35's Avatar
Why do I bother to DIY???
My PNRD shift light just went out! The weird thing is that it has been on the fritz for the past couple weeks...sometimes on, sometimes off. When it's off, I just needed to tap the metal plate and it would come back on...now it seems to be permanently off.
If the bulb actually blew out, it wouldn't have behaved so erratically would it? Maybe its a lose connector. The check/bulb replacement is a piece of cake right?
Old Dec 20, 2006 | 07:17 AM
cato's Avatar
SouthernComfort Moderator
Stealership charged me $28 to replace the two bulbs in my clock. That plus labor came to $40. Stealership!
Old Dec 20, 2006 | 07:28 AM
Floyds_racing's Avatar
you got a good deal its 105 to roll it in at Clear Lake Infiniti!
Old Dec 20, 2006 | 02:20 PM
RocketG35's Avatar
I need info on the shifter...
Old Dec 20, 2006 | 03:04 PM
LuXXXz's Avatar
yeh i have the shifter light out too and the passanger side little light on the heated seats button as well
and the fu*king Cd changer just went as well
and im out of warranty
FU*KING G35 is pissing me off recently
this summer im gettin the 06 M45
Old Dec 20, 2006 | 11:56 PM
lexusk8's Avatar
There is a TSB fix on http://www.infinitihelp.com for replacing the clock bulb in the '03-'04 sedans. Here's the link below:
http://www.infinitihelp.com/Ownershi.../ITB03-065.htm
For removal of the clock, you'll have to refer to the Infiniti repair manual, or if you're lucky, do a search for clock removal in this forum. Hope this helps
mike730
Jan 12, 2018 04:25 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
newbdriver01
Jul 15, 2015 06:10 PM
