Is there an easy way to get the cigarette lighter drawer out?
Originally Posted by brandon1978
If you have a 2005+ 6mt, it is quite easy. Put the shifter in 4th, push your fingers into the shift boot, hook them in the direction of the armrest, and pull up. This will pop out the entire section containing the shift-boot and ashtray. I have heard it is much more difficult for previous models, and would be different for automatics.
I have the opposite problem, my console somehow shifted a little and I can't get mine to close
I also have the same problem as one of the previous posters where the rear ashtray fell off and I can't get it back on either. I guess I'll ask the dealer to fix that too.
Hopefully they're nice enough to fix these things w/ no charge, WHY DIDNT I GET THE EXTENDED WARRANTY?!?!
Originally Posted by kinpcgeek1
I have a coin stuck somewhere in my ashtray as well, and it will not close. Is there a simple way to remove the center console in a 05 AT Sedan?
hahha....i thought that I would be the only person with this problem....This happened to me about 3 months ago and I still havent fixed it.
Originally Posted by ttrank
It's the same on the 04 6MT.
Thank God it isn't just me. I probably have 8 dollars in change jammed in my ashtray and it decided to get stuck the day I decided to clean it out. I'm gonna let the dealership take a look at it next time I go in for service.
i jus did it. jus put it in 4th gear and pull up right behind the shift **** and it pops right out....... no my thing opens and closes again after i turned it upside down and jiggled all the loose change in their
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
