Razo shift knob install
Old Jun 25, 2003 | 08:38 PM
Howard's Avatar
Razo shift **** install
I've tried searching, but can't find exactly what I'm looking for.
I just got a Razo shift **** and would like to install it.
Can anybody point me to the directions to remove the old one?
Any suggestions on the install would be great too.
Thanks
Old Jun 26, 2003 | 12:17 PM
Rumble's Avatar
Re: Razo shift **** install
I have the same **** and the install is very easy. To take off the org. ****, just pull the silver base of the **** down. You will then see a "U" clip facing the radio. Pull that out and once you do, the **** comes right off as you pull up on the ****.
In terms of the Razo install, place the BOTTOM **** cover in first then slide the metal thick ring down with the all the parts it came with. Those flexi small metal peices are to protect the screws from diggin into your org. shaft. Slide the ring in and tighten the screws a lil so that the ring stays in place. Place the TOP **** cover on the white plastic shaft and from there measure the travel with pressing the **** up and down. Once you have it right, you can tighten the two lil screws and twist the BOTTOM and TOP **** cover together. It may take you a few times to perfect to the way you like it, so it's up to you.
If you need anything else, just gimme a shout.
It's still a G thang!!
Old Jun 26, 2003 | 02:40 PM
IQ9's Avatar
IQ9
Rumble can you post pics of your shift ****. I wanted to see it installed. It is for the auto right?
03.5 Sedan/B. Silver/Prem/Winter/Aero/Tint/Rims
69 Chevelle Hard Top BB/4.11's/Posi
Old Jun 26, 2003 | 05:40 PM
Rumble's Avatar
Here ya go...and yes...my car is automatic. It just looks like manual. [img]/w3timages/icons/smile.gif[/img]
<img src=https://g35driver.com/rides/spec/pix/Rumble_1051577715.jpg>
Old Jun 26, 2003 | 11:34 PM
Howard's Avatar
I will try this weekend and let you know how it goes.
Thanks.
Old Jun 26, 2003 | 11:53 PM
IQ9's Avatar
IQ9
I WANT IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! How do I get it?
Old Jun 27, 2003 | 12:47 AM
Rumble's Avatar
Howard > Cool cool...hope it helps.
IQ9 > Haha!! I got mine at a local performance shop for about $80-90CAD i forgot exactly.
Old Jun 27, 2003 | 09:16 PM
Howard's Avatar
I got mine on ebay for $35.
Old Jun 27, 2003 | 11:18 PM
IQ9's Avatar
IQ9
Damn both of you[img]/w3timages/icons/smile.gif[/img] I'm looking tonite online.
Old Jun 29, 2003 | 07:54 PM
Howard's Avatar
Thanks for the help. It was actually pretty trivial.
Take a look. I might change it for a silver one later.
https://g35driver.com/forums/showfla...sed&sb=5&part=
Old Jun 30, 2003 | 12:32 PM
Rumble's Avatar
I'm glad the razo **** went on okay. Nice spoiler [img]/w3timages/icons/smile.gif[/img]
Old Jul 16, 2003 | 03:43 PM
gerryd's Avatar
Can you tell me what the part number is for the Razo shift **** you installed? I've been looking for it online, and Razo makes thousands of them. Did it come with the leather boot around the bottom? Do you happen to know if it would fit the Coupe automatic? Thanks!
Old Jul 17, 2003 | 01:40 AM
Howard's Avatar
RA-89 is the silver one.
RA-94 is the black carbon fiber one.
The boot does not come with it. It should fit all automatics.
Old Jul 17, 2003 | 12:48 PM
gerryd's Avatar
Great, Thanks for the info!
I've got one more question. My current automatic shift **** has a button on the side that you have to depress to get it into and out of "Park." The Razo's don't appear to have a button. How does that work? With the Razo's, is the button always depressed? Thanks again!
Old Jul 17, 2003 | 01:18 PM
Rumble's Avatar
When you place ur hand on the ****, you'll know. The whole **** moves up and down instead of a button at the top. So, it works the same way as a button, but just that the whole **** moves to keep the MANUAL shift **** look. Good luck.
