04 Heated Seat Problem
Old Aug 30, 2005 | 09:12 PM
P_Diddy's Avatar
I have a coupe and I thought I noticed the seat heaters were not working either. I will definitely re-check them tonight to see if they are working, because I'm taking the car into the dealer tomorrow for something else.
I recently installed some stereo stuff in the car. If the heaters are not working, I hope the dealer doesn't blame it on my stereo work.
Old Aug 30, 2005 | 11:47 PM
BrianV's Avatar
It sounds like there is some control that prevents them from working. For instance, my low-mode worked wonderfully this morning but switching it to hi-mode was the same thing as turning it off (cooled down).
I know you'll definitely feel it too because the hi-mode is often uncomfortably hot. Regardless of the ambient you should be able to feel it. Also my car will be well cool after a 30 minute drive with the A/C on so the surface of the passenger seat has cooled yet with the heater on you can't feel any warmth.
Ask the dealer if they know anything about it. My buddy with a Jeep told me to put the heated seats on for my back (which has been bothering me as of late). He drives year round with his heated seats on (even if it's 100 degrees out).
Old Aug 31, 2005 | 08:19 AM
G35_TX's Avatar
Originally Posted by BrianV
So on my 30 minute commute home, after 20 minutes of it on at the High level I turned it to the Low-Level and suddenly it started getting pretty warm. I switch it to High and it got cooler, switched it back to low and it got warmer. I left the passenger seat on Low for 10 minutes and it didn't get ANY hotter.
Something is REALLY weird here.
On high the heater has a temp sensor I believe that cycles. On low it does not cycle. Maybe its sensing its too hot inside the car already so it thinks the heater is hot? I dunno just a guess.
Old Aug 31, 2005 | 08:37 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
The elements are protected with thermal cutouts.
After they cool the element will energize again.
Old Aug 31, 2005 | 11:13 AM
Corgidog's Avatar
I got my 05 in late April. Recently I tried out the heated seats and only the passenger seat got relatively warm but the driver's seat did not. I will bring it to my dealer the next time I go. It looks like Infiniti dropped the ball in their design of heated seats as there are too many problems it appears based on this post.
Old Aug 31, 2005 | 11:18 AM
BrianV's Avatar
I wouldn't go as far as saying that. Mine worked FLAWLESSLY in the winter. I think what Russ said above might be the case. No body runs heated seats when it's 80+ degrees outside so there's probably something built-in to disable them or partially disable them because they can accidentally be turned on pretty easily.
Old Aug 31, 2005 | 12:07 PM
Corgidog's Avatar
Based on my car that is not the case because 1 seat worked and the other did not in 90+ heat. I think it would be tough to defend the design of the heated seats in the Infiniti as there appears to be many cries of dissatisfied people regarding heated seats.
arora_g35
Apr 16, 2026 02:52 PM
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Rokafor
Jul 29, 2015 11:50 PM
vstypicals
Jul 20, 2015 10:55 PM
