Which Plenum Spacer to buy and how much hp increase expected?
Originally Posted by gq916
Is it really worth it to buy a plenum spacer? and how hard is it to install.
And they are quite easy to install. Just open up the plenum like a clam shell and slide in the spacer. If you do the Iso Thermal kit you would also have to switch out a lower gasket, but its not hard.
A spacer will typically yeild anywhere between 8-13 HP.
Tony
