FAQ: 15K Service Charge
Old Sep 12, 2005 | 02:13 PM
number2's Avatar
Had the 15K service today at Austin Infiniti
Normal 15K service = $200
Minus the optional cabin filter change = ($120)
Net Service = $80
Not bad
Old Sep 12, 2005 | 03:30 PM
tonyj's Avatar
What all did they do?
Old Sep 12, 2005 | 03:55 PM
number2's Avatar
rotate tires, oil & filter, reset ECU, inspection of belt, brakes
top off fluids
car wash
with a loaner car
Old Sep 14, 2005 | 02:36 PM
trebien's Avatar
$80? For an oil change?
The cabin filter is less than $30. The airfilter should be less than $10.
To each their own, but for $55 from Grubbs you can get an air filter, cabin filter, 4 oil filters and cruch washers. But 4 of the 5 quart oil containers from Wally World for $8 (I choose Castrol GTX), and you've got the 15K service covered AND 3 other oil changes for $87.
And you get the satisfaction of knowing it's done right. Splurge on a fumoto valve and that'll be the best $25 you spend.
Even if you don;t want to mess with oil changes, the air and cabin filter changes are easy and you can save a lot of money.
f22raptor
Mar 18, 2016 08:50 AM
