30,000 Mile Maintenance
Old Sep 14, 2005 | 05:29 PM
medgar's Avatar
Hello! I just purchased a 03 Sedan with 27k miles on it. Upon reading the manual I found out that the car requires a major overhaul at 30k miles. The Nissan dealer near me wants $600 for the service. Is it worth it? Should I pick and choose the services that will help the over all life & performance of the car? I have been told that in the long run it is worth it. Any opinions on this?
Thx
Old Sep 14, 2005 | 06:14 PM
DaveB's Avatar
Thx
I think the only things that really need replacing are the oil/filter and cabin filter and maybe rotate the tires. The tranny fluid, gear oil, coolent, belts, and plugs don't need changing for a long time (60K+ miles) per the recommendations in the owners manual though lots of dealers will tell you otherwise so they can sell you services you don't need. Live by the owners manual, not what dealership tells you. The manual was written by Nissan engineers. Dealerships are run by businessmen.
Old Sep 14, 2005 | 09:48 PM
KC2CAG's Avatar
Wink 30K mile service
My local Infiniti dealer wanted about $600 for the 30K service as well. I shopped around and found that "Brakes Plus" (a franchise in the Denver area) would do all that Infiniti would do, except replace the wiper blades, for about 1/3 the price. Brakes Plus even did a 4 wheel alignment and a fuel injector cleaning for their price, and documented the service to meet warranty requirements. I don't have anything against the local Infiniti dealer, (they are nice folks and reasonably competent) but I think their charge for the 30K service is quite overpriced.
TK 2003 G35 Sedan 5AT
Old Sep 14, 2005 | 11:40 PM
DaveB's Avatar
Where is fuel injector servicing required in the owners manual?
Purely my opinion, but I've owned 5 fuel injected cars over the past 16 years and never once have I had injector problems. 3 of those 5 cars were drag raced quite regularly too. Injector cleaning seems like snake oil to me. If you've got clogged injectors then you have more serious issues to contend with.
Old Sep 15, 2005 | 03:15 PM
jl9618's Avatar
I'm in Denver too, Highlands Ranch to be exact. Where abouts are you? Which dealer quoted you $600, the one on Havana or Peak on Wadsworth. I like Peak better but they quoted me $840 for the 30K check and I was like screw that. My indy mechanic did everything for me and put some aftermarket stuff on for $300 and change
As for the 30K service, check the owners manual for the REQUIRED service. The dealer throws in a bunch of fluff that they RECOMMEND but is not required. That's where they make their money.
Old Sep 16, 2005 | 01:18 PM
sickpig's Avatar
I just called Major Infiniti in Kansas City. Sounds like they do exactly what the manual calls for for $317.00. Oil/filter, air filter and in-cabin air filter changes. Rotate tires and "adjust" air pressure. Mostly "inspections". (Most likely a quick glance by the guy changing the oil.) Everything that I already do myself. How hard is it to change the in-cabin filter? They want $110.00 to do that.
Mark
Old Sep 16, 2005 | 02:13 PM
jl9618's Avatar
I didn't change mine myself but from what I've heard its definitely NOT $110 difficult. 30 minutes max is what I've heard it takes to change it.
BTW $317 sounds high for the 30K service
Old Sep 16, 2005 | 10:30 PM
NICE1's Avatar
trans is sealed - 100 k
religiously - change oil, coolant, air-filter(performance, mileage) ---
that's it.
enjoy the car, it's awesome
Old Sep 18, 2005 | 10:08 AM
SixFive's Avatar
So even if we downshift a whole bunch we don't need to step up the service schedule. My car has 28,500 miles and since I drive a lot of non-hiway miles I would do it at 30k or at least 60k.
What's the schedule for coolant?
Old Sep 22, 2005 | 03:12 PM
barrios35's Avatar
Cabin filter Instructions: Not worth $110...
http://www.infinitihelp.com/Ownershi...AirCFilter.htm
Old Sep 22, 2005 | 03:13 PM
barrios35's Avatar
Maintenance Guide.
http://www.infinitihelp.com/Infiniti...nce/G35/30.htm
chinee
Jun 10, 2024 07:48 PM
derres
Aug 28, 2015 03:27 PM
EPG35
Aug 16, 2015 04:52 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Mac8008
Aug 4, 2015 09:19 PM
