I need anyone with the stock sport suspension to do me a favor. I need some measurement's that are supper easy. I need you to know the car's stock ride height, I forgot to measure before I did the 350Z springs and sturts install. All I need if for someone to use a tape measure and measure the distance from the ground to the top of the fenderwell arch front and rear. It's info I must have to do a through write up on what 350Z springs and struts do for the sedan.
I could go to the dealer, but that's a hours drive on way, please help me out so I don't have to do that.
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
clear corners
Ivry 6mt sed
Kumho MX 245/40
clear corners
Here you go,stock sport suspension Sedan
Front= 27.75"
Rear= 27.50"
Send me a copy of your write up.
Good Luck
Mike
Front= 27.75"
Rear= 27.50"
Good Luck
Mike
2nd opinion: 28" front, 27 5/8" rear
30lbs air pressure all around.
03.5 Sedan AT (Black-Willow-Premium-Sport-Aero-GG Grounding Kit)
All of your post replies appear twice!
God I love this car!
I did it. Slow response once I hit the "Continue" button so I hit it again. Cheap way to up your post count!
When I do that, it always comes back with a "your post already exists" message. Strange.
get the body weight of the driver in both the above cases as then you can ratio it to yours as the car will settle lower on the driver's side than on the passenger side unless you always carry passengers.
Better Life thru Chemistry
I think I was very impatient and didn't give it a chance. I have posted twice and received the "post exists" message.
Thanks for the measurement's guys. I played it safe and used the higher measurements. For the 350Z springs and sturts review and to see how much they lower the car go here.
https://g35driver.com/forums/showfla...b=5&part=&vc=1
Ivry 6mt sed
Kumho MX 245/40
clear corners
Ivry 6mt sed
Kumho MX 245/40
clear corners
