19" oem rims rub on my sedan
Old Oct 12, 2005 | 12:13 PM
norcalG35er's Avatar
So I finally found some 19" coupe rims and put them on my car, love the look & handling, but they rub sporadically. Before I bought them I searched the forums and didn't read anything about the stock rims rubbing. It happens when going over a dip in the road, or when I have four people in the car. Other then rolling the fender, what are some things I can do to prevent this.
Old Oct 12, 2005 | 12:39 PM
wanalaugh74's Avatar
Hmm that's wierd. Have you lowered your car? I have the Tein's on my ride and have had 4 people in my car and no rubbing while driving on the interstate. Even over the speedbumps. Granted I went over the speed bumps at an angle but still....
Old Oct 12, 2005 | 12:44 PM
Gsedan35's Avatar
You didn't find this 19" coupe rim on sedan thread where I said this,......
Originally Posted by Gsedan35
I'm afraid that the 8.5" wide rear's will rub. Ride quality, I wouldn't worry about.
https://g35driver.com/forums/showthr...&highlight=rub
Old Oct 12, 2005 | 01:23 PM
vodkarocket's Avatar
Modded Member
Besides rolling your fenders, you can increase the negative camber on the rear wheels so that they aren't angled directly at the fender lip.
I suggest you get a set of OEM 350z springs or Tein H-Tech's- they may give you that negative camber you are looking for without requiring a fender rolling.
Old Oct 12, 2005 | 02:37 PM
codeflux's Avatar
when all else fails, use hub-centric wheel spacers.
Old Oct 12, 2005 | 02:58 PM
jran76's Avatar
Wheel spacers would make the problem worse. Negative camber or rolling the fenders are the only way to avoid the problem. Negative camber will bring the top of the wheel in away from the fender. The obvious drawback is increased/uneven tire wear.
Old Oct 12, 2005 | 03:32 PM
Jeff92se's Avatar
Red Card Crew
Why do some of the pics look like they are all garbled?
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
jjohns2711
Aug 5, 2015 08:58 AM
multimut
Canada
Jul 26, 2015 08:43 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
