Q: G-sedan is leaning, need help
Old Oct 17, 2005 | 05:42 PM
MikeyMike's Avatar
Rollin On Dubz
There's nothing wrong, that's the way it's supposed to be.
Old Oct 17, 2005 | 08:45 PM
trebien's Avatar
I friend of mine had a similar problem.
He just got a bigger girlfriend.
Old Oct 17, 2005 | 08:57 PM
Andy2434's Avatar
LMAO!
Seriously, if in question, call your service people.
Old Oct 18, 2005 | 01:42 PM
myst's Avatar
HAHA. That's funny.
I think my car is a bit lighter on the passenger's side too. When I carry a passenger, then the car feels more balanced. But who wants to carry people?
Old Oct 18, 2005 | 03:44 PM
trebien's Avatar
Originally Posted by andycon
...but there might be perks Especially since I would probably need 2 of them
Yes. They would need to be perky.
Old Oct 18, 2005 | 11:44 PM
superb16's Avatar
I have had this same problem...WITH EVERY CAR I'VE OWNED. It's normal. If you drive your car alone most of the time it will happen. The difference was about 3/8".
Old Oct 19, 2005 | 12:36 PM
superb16's Avatar
ahhh... no offence, but how much you weigh?
It seems quite unusual to me, and something that is really noticable now, not before - I suspect something is wrong with the sway-bars - will disconnect them and see how it sits.
I'm a featherweight. The same thing happens to most cars. My friends (no fatties) also notice the same thing on their cars.
Old Oct 19, 2005 | 06:12 PM
Crespo's Avatar
happen to mine 05 sedan too. My car was leaning to the passenger side when I got it just for two weeks. Infiniti just changed a new suspension for me.
Old Oct 24, 2005 | 11:21 PM
dcreigh1's Avatar
Since I work for an OEM and have done tens of thousands of alignments (as a Quality Engineer), I believe that I am qualified to answer this riddle. First though, I'd like to ask a few questions and then send you in a couple of directions.
1) was it sitting like this when you purchased the car?
2) Did it just happen after the suspension change
- were there spring and strutt replacements?
If you noticed it after the suspension swap, chances are that the culprit is in the spring and strutt. They can vary over time but not very likely. The other option is that the car was allways like this and you just noticed it. If that is the case, then its in the sheet metal the way that the sidemember and hang on parts are attached. If its the S/M, then there is nothing you can do. If the height of the car when calculated off the axle assembly is correct from left to right, then there is nothing to worry about.
If it is in the springs, change them from left to right. Sometimes this makes a difference. At MB our supplier, Bilstein, compresses the springs to a certain weight and then checks the drop in height to what it is supposed to be. They then add shims to get the rideheight to the proper position. Try the swap process, if its still bad, chances are its in the S/M and if you really really want to change it and have the left equal the right, then add shims to the springs and strutts.
Hope this helps.
