Exhaust question from newbie...
I just got my sedan two weeks ago and I'm loving it! Since I started doing the research while looking for a car, I've realized how much fun cars can be! I'm new to all of this and I have no idea about technical/mechanical details (but I'm learning) so here's my question...What can I do or what can I get to make the exhaust sound on my sedan sound more like the coupe. I just want a stronger sound when I accelerate and I dont want to lose any horsepower. Thanks a lot!
Re: Exhaust question from newbie...
Unfortunately, there's no way to determine what an aftermarket exhaust sounds like until you've actually put it on or unless you hear it on someone's car. If you want something similar, then I would suggest you go with Nismo's system.
If you are really looking for the coupe sound
dun go for GReddy because it maybe too loud for your taste
I am not saying GReddy is not good because I really like mine, the gain in power and the look is just perfect
Maybe you can also look into HKS because I downloaded the audio clip in the mod section and it sounds pretty low, deep but not too loud
Also, not sure about the sound, Stillen will have a new exhaust sys coming out
2003.5 5AT Sedan / Silver / Tint / Clear Corner / Greddy Exhaust
Even picking a muffler based on how it sounds on another G35 is a bad idea. Other engine mods such as a high-flow cat can change the sound of the exhaust.
On my Acura Integra GS-R, the Carsound/Magnaflow high-flow cat converter I put on made the car louder than when I installed the new exhaust system.
Dan Parmelee
2003 Infiniti G35 Sedan
1999 Acura Integra GS-R coupe
2001 Infiniti I30t
Dan Parmelee
2001 Infiniti I30t
As far as exhaust note goes, the Magnaflow 14829 Muffler makes a great sound when used on the vq engine in altima trim. On a side note however, that is with a dual exhaust. I think the G will actually turn out better performance with a single exhaust, but the exhaust will be much louder and racier with a single exhaust.
Just an FYI to add to the confusion
Additional benefit of single versus dual is the weight. (you can lose about thirty lbs with a single exhaust if done right) However the stock components are pretty thick and a dual exhaust may actually be lighter than the stock exhaust.
All these argument are based on a "cat back" system not jsut muffler replacement
Better Life thru Chemistry
