350Z springs lower front/rear unevenly?
Old Nov 9, 2005 | 05:43 AM
geeitup's Avatar
I've seen some sedan members have had a problem lowering with 350Z springs and the ride height being higher in the front, vs. the rear. I've also read this could just be an illusion due a difference in the front/rear wheel wells? Just wondering what most have experienced. Also, has anyone attempted to mix rear 350Z springs with different front springs in an attempt to get a good ride height? Coilovers would be nice but don't want to go that expensive - unless the Megan Racing coilovers ($850) prove suitable. Thanks for the help.
Old Nov 9, 2005 | 09:25 AM
ajayjuneja's Avatar
do not use z or g35 coupe springs in the rear, they are too short due to the different mounting points of the shock tower in the sedan.
Old Nov 9, 2005 | 10:18 AM
trey.hutcheson's Avatar
Could you elaborate? Are you discouraging using coupe springs only without shocks, or coupe springs with shocks? If the latter, then I must disagree. There are plenty of people with that setup, that have not experienced any problems.
geeitup: I suggest that you direct all suspension questions to Gsedan35; he seems to be *the* authority on our suspensions.
Old Nov 9, 2005 | 09:11 PM
Teeter's Avatar
Yes and yes. The front fender gap on my '05 Sedan was 5/8"-3/4" bigger than the gap on the rears. It looks bad enough at stock ride height, so I knew lowering would only make it look more exagerated. So when I lowered, I used 3/8" spacers ("seats") on the rear springs to even this up. And it came out looking great. -T
Old Nov 9, 2005 | 10:00 PM
e-low's Avatar
Im lowered on 350z springs, and the ride is a tad higher in the front, but not by much. Its not nearly as noticable as the stock sport springs. I'll post some pictures of it when i get my camera back tomarrow. Its riding on 19x8.5, 19x9.5 Ruff Racing 279/ Dunlop Direzza 245/35/, 275/30. The ride height look's perfect now IMO. Id say go with the 350z springs and see how you like them. You can get them for under 100$, In my case for free, some people just want to clear out their garage, you may get lucky as i did. If they dont meet your standard, then go for a coilover or differnt spring. I think the Tein springs lower the front a half inch lower in front. They are cheap as well, can easily get them for 150$ But you dont get the firm linear spring rate of the sport/350z springs.
Old Nov 10, 2005 | 09:41 AM
g35john's Avatar
I think the the Z springs do lower the car evenly. Its just that the fender gaps in in the rear and the front arnt even to start with. Not many cars are. I still think it looks good though.
Old Nov 10, 2005 | 09:58 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
That's just not true..
Here's my sedan on '05 Z springs.
You will get less sag with the '05 springs with their higher spring rate.
Old Nov 10, 2005 | 04:00 PM
Endless G's Avatar
What if you have the 05 M6 Sport sedan, do the 05 Z and the 05 sedan have similar suspension!!
Someone confirm this please
Old Nov 10, 2005 | 05:18 PM
InTgr8r's Avatar
Similar but not exactly the same.
Z shocks are different
& rear springs are slightly stiffer.
My '04 had sport suspension which I believe is unchanged for '05.
(someone jump in if I'm wrong)
neight
Interior
Sep 21, 2015 05:35 PM
Kicknshift
Sep 3, 2015 09:35 AM
xplosive1
Steering & Suspension
Aug 1, 2015 03:01 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
