Hey i have A question i am running 18/8.5/40 with a 35mm offset on 265's.. if i got rims that where 9.5 in the rear with a 45mm off set with the same tires 265's would it look the same as this.I thinking it would..
I have a 9.5 wheel with a 35 mm offset and they don't stick out of the wheel well as much as yours do.
Are you sure your wheels are 35MM and not the coupe 20MM?
Can we see pictures of your car from the side not so close up I would love to see what it looks like with that offset...
Quote:
I think it's because of the 265 tires.Originally Posted by shodog
These rims are 18/8.5 with a 35mm offset on 265's. If i were to get 18/9.5 with 45mm off set with 265's, would i still have the same problem with the wheel sticking out???
Quote:
No.Originally Posted by EQUATE
Try this link. This should tell you how much more less it will stick out and how much more room will be taken in the inner wheel well.
Wheel Offset Calculator
