Christmas came early Axis Milanos.
Old Nov 25, 2005 | 02:15 PM
perry05G35's Avatar
Set of 4 19X8.5 245/40/19 +35mm offset on all 4 with 5x114 bolt pattern. For my 2005 PS sedan. My question is will I have problems with the tire pressure monitoring system? I did a search one person had problems with warning staying on but I can't tell if it's because of the wheel brand and size or just something to expect when not using the factory 18" wheels? How exactly does the sensors work on the sedan? Another question can I use my factory lug nuts?
Posted this tread in the wheel tire section never got a response...
Old Nov 25, 2005 | 02:41 PM
MikeyMike's Avatar
Rollin On Dubz
Off topic question....
Are you dropped at all? If so, do you have any rubbing issues?
PS..POST PICS!
Old Nov 25, 2005 | 04:11 PM
jimmyc13's Avatar
I responded to your other thread w/ the same topic....check it out. Any reason you posted the same thread/question twice?
Old Nov 25, 2005 | 10:57 PM
my_Gthang's Avatar
pix???
Old Nov 25, 2005 | 11:30 PM
perry05G35's Avatar
Like I said before I posted in that section and didn't get a resonse so I posted here to see if anyone could answer me. I don't have pictures of the wheels on my car yet because I just brought them today. I have to wait until they are shipped to Hawaii. PIXS will be coming I have a silver with the full factory areo package so the wheels will look great not to mention the offset will make them flush with the fenders!
Old Nov 26, 2005 | 01:06 AM
Chico's Avatar
Sensors have nothing to do with the make or size of the wheels. If you don't install them on the new wheels, the warning light will come on your dash ONLY after about 45 minutes of highway driving. During city driving you will not see the light at all.
The sensors measure the PSI of the tires and when the PSI falls below 28 psi the sensor triggers a signal which lights up on the dash to warn you the tire pressure is low on one or more of the tires.
I don't think the sensors can be fitted on the Milanos.
Old Nov 26, 2005 | 12:48 PM
perry05G35's Avatar
DAMN...DAMN...DAMN!!! I will have to do some research on the sensors with Milanos I like the idea of having the sensors...
Old Nov 26, 2005 | 01:56 PM
killerlexus's Avatar
pics?
Old Nov 26, 2005 | 02:54 PM
perry05G35's Avatar
The wheels are being shipped once I get them on my car I will post pixs at that time. I purchased the wheels from ebay they were mounted on a TL. I just wanted to know if I could use my Sensors with the Milanos and seems they will fit after all!
Old Nov 26, 2005 | 04:01 PM
MikeyMike's Avatar
Rollin On Dubz
TL and G sedan have the same offsets?
Old Nov 26, 2005 | 04:35 PM
perry05G35's Avatar
The offset can be any range and deals with the wheels spacing within the wheel well. The TL, Maxima, G35, Altima etc... Have the same 5x114 bult pattern. The wheel and tires weigh 50.8lbs stocks are 51lbs I could have went with a 35 profile and shaved more weight 48.8lbs but I don't want to lower the car but want that lower look that the higher profile and areo kit gives me.
Old Nov 26, 2005 | 05:34 PM
ryansg35's Avatar
Future Sedan Freak
what about lexus is 300? are the offsets the same as our sedans? for staggered? 18x8.5f 18x9.5r.
Old Nov 26, 2005 | 08:56 PM
perry05G35's Avatar
I think the bolt pattern is the same 5x114 since the GS has the same bolt pattern as us but again offset and bolt patterns are two different things. What is the offset of the staggard wheels on the lexus?
Old Nov 27, 2005 | 01:38 PM
ryansg35's Avatar
Future Sedan Freak
it actually came from a g35, and will try to put it on a IS300. i think the offset for front is 45 and rear is 35. will it fit?
Old Nov 27, 2005 | 04:19 PM
perry05G35's Avatar
I am pretty sure you meant to say the offset in the front is 35 not 45 and the offset in the rear is 45 not 35. They will definitely fit on the IS300 they MAY NOT line up with the fenders like they do on the G35 though because I don't know the factory offset for the IS300. Look on clublexus.com they should have some staggard IS300s on there with the offset.
