wheel fitment
Old Jan 5, 2006 | 01:23 AM
dtmk1d's Avatar
wheel fitment
Hey whatsup guys I was wondering if I would run into any problems running 18 x 8 front and 18 x 9 rear with +46 offset all around with 235/45 tires all around or should I go with a staggered performance
Old Jan 5, 2006 | 01:44 PM
perry05G35's Avatar
ask the same question in the wheel and tire forum that where the wheel tire experts hang out.
Old Jan 5, 2006 | 02:09 PM
Chico's Avatar
You will be ok...but if you're gonna use an 9" wheel in the rear, you should consider a 255/40 or even a 265/40 if available in your size. Otherwise, you should stick to the same wheel width with a 235/45 all around.
One more thing...using such a high offset will make your wheels look tucked in and the front will be pretty close to the suspension. If you can try to use a +35 in the front.
Old Jan 5, 2006 | 11:06 PM
dtmk1d's Avatar
thanks for the reply wouldn't I be able to use wheel spacers to decrease the offset? and I apoligize for posting in the wrong board just thought since there going on a sedan it might work in here
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
joedaddy1
Jul 28, 2015 02:58 PM
Soumilg
Jul 18, 2015 12:33 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
